Other Parts Discussed in Thread: CSD86350Q5D
Hi TI Team,
I Thought of using TPS53119 in one of my project, where my requirement is Vin : 12VDC (Nominal), Vout : 0.8V, Iout : 20.6Amp(Nominal) & 22Amp(Max). I had simulated the same in webench(even i have selected the part through webench) and the results are fine, while i was checking the data sheet and part information it was written that MAX current is 20AMP as mentioned in the below images First one refers from Part Details & second one is from Webench.
Even i have tried te rise time & load transient analysis and results look good. attaching report for the reference.
5672.WBDesign56.pdf
Hence i request you to clear the confusion over the same & let me know weather can i use the this part for my requirements.
