Part Number: ATL431LI
Other Parts Discussed in Thread: ATL431
Do you have a minimum and maximum voltage level for the Cathode when using the ATL431 as comparator?
Datasheet only states that the voltage will be approximately around 2V (datasheet section: 11.2.1.2.2 Output Voltage and Logic Input Level), but this is not sufficient information to create a reliable design.
Can you please provide minimum and maximum voltage for the cathode when the reference pin is overdriven?
Kind regards,
Tom
