Hi team,
From TPS51200 datasheet on page 38, this recommendation is based on 0.125mm thick stencil.
What if customer uses 0.08 or 0.1 mm thick stencil? Please give me some comments or guidance on this.
Izzy
Hi team,
Izzy
Hi Izzy,
I found a document that might shed some light on this, this is talked about specifically on page 10, linked here under the 'Solder Stencil' section. Based on this information, typical manufacturing stencil thickness is around 0.1mm - 0.15mm and 0.125mm is recommended. Using other thickness might also require some change, but I think 0.1mm should be fine and is on the lowest end of the range, but 0.08mm might not be.
Field
