We are using the CP2112 USB-SMBUS Bridge to read and write data to the BQ78350-R1A. While we have been successful in reading data through the CP2112, however we are unable to write any data to the registers. We are using C for performing the operations.
The format for writing data as per the CP2112 documentation is as below:
HID_SMBUS_STATUS HidSmbus_WriteRequest (HID_SMBUS_DEVICE device, BYTE slaveAddress, BYTE* buffer, BYTE numBytesToWrite)
Considering we want to toggle the LED using the manufacturer access, 0x002B is to be written to the manufacturer access 0x00. We have written the code as,
BYTE* buffer[] = {0x00,0x2b00};
SMBus_Write(HIDDEVICE, buffer, slave_address, 3);
However, this seems to be the wrong format/syntax as we arent getting the outcome.
Would appreciate if someone can show the right syntax for writing data to the registers. Thank You.
