Other Parts Discussed in Thread: BQ2982
Hello E2E Experts,
Good day.
I have two questions:
1. For BQ2980/ BQ2982 the OVP triggers at 4.475V. For the LiFePO4 battery, the nominal voltage being 3.6V, will this IC be able to protect the cell? In other words, since the trigger voltage is much different than the nominal voltage, is a LiFePO4 cell safe to use with this charger?-or will it overcharge before safety is triggered? The data sheet I am referring to is here https://www.ti.com/lit/ds/symlink/bq2980.pdf?ts=1683279241160&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FBQ2980.
2. In the datasheet, I find the following table on Page 6:
Can you elaborate on which value corresponds to which IC for each of the above parameters?
CSC
