1) When Adapter is present, does the charging voltage appear at the SYS terminal during charging and does the adapter voltage output to the SYS terminal when not charging?
2) Events that cause a reduction in charging current also cause the charging safety timer to count at half-clock rate if TMR2X_EN bit is set.
How does the timer operate from the point at which the event causing the charge current to decrease is resolved?
Kagawa
