BQ40Z60: Wake without charger
Part Number: BQ40Z60
Referring to
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/446697/bq40z60-wake-command-with-no-charger-present
I would prefer to be able to set some parameter that will allow activity on the SMbus to move the device from SHUTDOWN mode to some other mode.
Failing that, if applying voltage to AC is necessary, what is the minimum voltage and what is the minimum duration?
