Other Parts Discussed in Thread: BQ34Z100-G1, BQSTUDIO
Dear all,
I have two questions:
1.- We use the BQ34Z100-G1 in an 8S2P Lifepo batteries. So if we upgrade to R2 version (FW=2.01) can we use the same flash parameters, and it is not necessary to repeat a learning cycle, and temperature optimize cycle?
(only generate a new golden image based in the new firmware)?
2.- We updated the firmwate to R2 in a G1 device, Then BqStudio recognizes the new firmware change to 2.01, but the battery voltage is wrong (value=65535). I saw in some forums it is a bug of Ti. is it correct? When will be solved it?
So it means we have to maintain in G1 firmware (0.16) at the moment?
Thank you
Best regards.
