TPS54A20: Efficiency when driven at frequencies other than 4MHz
Part Number: TPS54A20
Hi, TI expert
I want to know about Efficiency when driven at frequencies other than 4MHz.
The EVM is fitted to 4MHz and the efficiency is 62%, but what happens to the efficiency when fitting to 7MHz and 10MHz and operating at each frequency?
In the above case, I think the efficiency will probably be low, but if I apply it to VG+, will the efficiency improve?
Thank you.
