Part Number: TPS25810
Hi team,
do we have TPS25810 checklist for reviewing ?
regards,
Fred
Hi Fred,
Thank you for reaching out!
Here is the checklist for TPS25810. You can also refer to the datasheet for this information.
Aya
Hi Fred,
I am going to check internally and get back to you on Tuesday.
Aya
Hi team,
please help sync with internal and see if we have USB vendor info file, thanks
Hi Fred,
Thank you for your patience.
The vendor info file (VIF) is created by the customer depending on their system requirements. This VIF is loaded onto a compliance tester and is what is used to tell the compliance tester what tests it should run.
You can generate this file through the GUI. Go to Project → Save Project Vendor Info XML.
Aya
Hi Aya,
the problem is " where can I find GUI"?
I can't find it on the ti.com.
would you send me the link instead?
Hi Fred,
I apologize for the misunderstanding. This device does not have a GUI associated with it. You can go to this website to generate a VIF: https://usb.org/document-library/usb-vendor-info-file-generator
Download the file to extract the tool which you can then use to generate a VIF.
Aya
