Excuse me .The picture below is my wiring diagram,connected
Power supply 12v and 3.3v
appear this picture error,how can i solve this error,right now LED is not light
Hi, wade
looks like device meets the charge pump problem.
pls follow the user guide to setup the device.
Hi, wade
If you used 3.3V, charge pump is needed.
if you see the flicker, pls check with the power capability of the input power.
Hi, wade
For LP8864, the addres is 0x3A and 0x3B, you can find it in the datasheet.
LP8866 is 0x2A and 0x2B.
the datasheet also tells you how to change it.
