The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
LMR50410-Q1: LMR50410
Part Number: LMR50410-Q1
Other Parts Discussed in Thread: LMR50410
I recently submitted a product for EMC testing using the LMR50410. The design of the regulator was copied almost identically from the EVM module. The product failed radiated emissions with spurious emissions in the 100Mhz to 200MHz region.
The board is pretty simple, consisting of a bridge rectifier, smoothing caps and LMR50410 to produce 5V. This is used to power a PIC18F running at 16MHz. The PIC design has been used in a previous generation of this product and hasn't changed here - the only difference is the new regulator, designed in due to stock shortages of the previous part.
Any thoughts or advice appreciated. I would be interested to see the radiated and conducted emissions test results from the reference design.
Greg
