Hi team,
The customer test the wave of SW with Vin at 5V. The find the SW voltage(5.7V) is more than 5.3V lasting 102 ns, which is longer than the time in datasheet . They want to know whether it could damage the device.
YOURS
NAN
Hi team,
YOURS
NAN
Hello Nan,
Thank you for using E2E,
Can you please provide me the measurements of input voltage(across the device input capacitor) and the SW node voltage using 1V/div in same scope plot.
Thank you & regards,
Moheddin.
HI Moheddin,
The picture is shown the SW wave, and you can see measurement result marked in red which means the max voltage in wave is 5.76V.
yours
Nan
Hello Nan,
I suspect the Vin is high that's the reason I am asking VIn and SW node voltage with 1V/div to make things clear. So can you please provide me the measurements of input voltage(across the device input capacitor) and the SW node voltage using 1V/div in same scope plot.
Moheddin.
Hi Moheddin,
Thanks for your continuous support. I have sent this to customer,but the customer have not any feedback. I will check with customer tomorrow.
yours
Nan
Okay, please update once you received the data from the customer.
Thanks & regards,
Moheddin.
HI Moheddin,
I get the test waveform. Vin marked in blue, SW marked in orange.
yours
nan
Hello Nan,
Thank you for sharing the waveform.
Now it looks like, Vin is around 5.1V and SW the peak is around 5.4V. There should not be any concern, but just to make sure about the layout, can you please share the customer layout, sometimes the peak of SW also depends upon the SW plane area and the measurement setup.
I would recommend the tip and barrel method for the SW measurements to eliminate the extra ringing, please have a look in here - (+) How to measure ripple for better design outcomes - Power management - Technical articles - TI E2E support forums
Moheddin.
Hi Moheddin,
The waveform seems like the light load oscillation which is caused by the inductor and the cap of mos. Am i right?
yours
nan
Hello Nan,
Yes, you are correct and this amplitude of the ringing and the frequency of ringing is also depends upon the SW plane area in the layout as it adds the parasitic inductance.
If you don't have any further questions, can you please close the thread by clicking on resolved.
Moheddin.
