Hi Team,
I have one question need you team help to confirm.
I see the TPS564208 only mention min off time 220ns, I want to know how about the min on time? Customer want to use it apply 12V convert to 1V, so we need to know this parameter, thanks.
Hi Team,
Hi, 1V is typical application in datasheet, should not touch the Ton-min, let's double check internally and feedback you ASAP.
Yuchnang
Hi Yuchang,
Understand, this application should be ok. If you can have the min on time parameter, pls share me. Thanks.
Kevin,
we just found typical is 220ns, but this data is only ensured by design. Not production tested.
Yuchang
