Hello expert,
Customer measured VDs waveform and found out the Max/Min is out of datasheet spec. Do you have any method to reduce this ringing? We change Rboot to 2.2ohm but it is still not working. We don't have space to place snubber.
For maximum, customer has a de-rating spec which is 80% ABS max. So based on datasheet, maximum H/S VDS should be 16V. Below waveform is over this spec.
For minimum, L/S VDS is -4.16 which is also way behind the spec. Please kindly provide the solution for us, thanks a lot for your help :)
Ann Lien
Ann Lien
