Hi Team,
The absolute max rating of mosfet is +25V and -10V but as I've used DCPA10515D the negative output voltage is -12V. I used two 1uF capacitors at the output side of converter between positive and common as well as negative and common.
I would like to reduce this negative voltage below -10V. Can you please suggest me some possible ways to do so. Thanks in advance!
Varun B
