I designed a 6cell lithium polymer battery charging circuit using the BQ24610.
I am using a 28V adapter and the battery is 25.2V when fully charged.
It is designed not to use DPM.
However, when the battery is connected without an adapter, one of C1, C2, C11, and C12 is randomly broken.
The recommended circuit says to use ceramic capacitors. Is using tantalum capacitors causing problems?
Please check if there are any other problems with the circuit.
please answer about my question.
