Other Parts Discussed in Thread: AWR2944
Hi Team,
My customer report that PG0 is always '0' in their design. (LP87702K-Q1) The radar is AWR2944.
For LP87702K-Q1, 0x14 register shows the PG level including VMON1 threshold and window.
1. I will check VMON1 voltage tomorrow. (1.17-1.23V)
2. May you let me know the normal PG voltage if our pull high voltage is 3.3V with 1.8k pull-up resistor. Is it 3.3V or 1.2V?
3. I don't understand the below part of datasheet. Does it mean that out VMON should ready no later 800us after enabling the LP87702K-Q1?
Do you have any suggestion that I need to check? Or can you share the common reason that PG0 doesn't work? Thank you.
Roy
