WSON described in the datasheet Is the LAND PATTERN correct?
Datasheet(bq2970) P31_32)
Hello Nudejima-san,
Yes, the drawings in the datasheet are correct.
Luis Hernandez Salomon
Luis Hernandez Salomon-san
Thank you for your support.
As I added to the datasheet.
I am concerned that the electrode will not protrude from the land pattern.
Am I thinking wrong? please confirm.
Hello Nudejima-san,
I am a bit confused on what you mean by this? Can you clarify?
The pattern should match the size of the IC with no issues. Although this is an example, so it can be adjusted based on what you would want.
