I am have downloaded the "LMR36503RF unencrypted transient Pspice model" from TI website and tried to run it in LTSpice. I have got a lot of errors as below:
Circuit: * C:\Users\user\AppData\Local\LTspice\LMR3650RF.asc
Questionable use of curly braces in "b§e_u1_e23 u1_n314041 0 v={limit(v(u1_n315325,vcomp),0,5)} "
Error: undefined symbol in: "limit([v](u1_n315325,vcomp),0,5)"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}}&v(b)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](a)>((vthresh))&v(b)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](a)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}},{{vss}},{{vdd}})}"
Error: undefined symbol in: "if([v](a)>((vthresh)),((vss)),((vdd)))"
Questionable use of curly braces in "b§e_abmgate1 yint1 0 v={if(v(a)>{{vthresh}},{{vdd}},{{vss}})}"
Questionable use of curly braces in "b§e_abmgate2 yint3 0 v={if(v(yint2)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](yint2)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(s)>{{vthresh}},v(b),v(a))}"
Error: undefined symbol in: "if([v](s)>((vthresh)),v(b),v(a))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}}|v(b)>{{vthresh}}|v(c)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](a)>((vthresh))|v(b)>((vthresh))|v(c)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}}&v(b)>{{vthresh}}&v(c)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](a)>((vthresh))&v(b)>((vthresh))&v(c)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}}|v(b)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](a)>((vthresh))|v(b)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}}|v(b)>{{vthresh}}|v(c)>{{vthresh}}|v(d)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](a)>((vthresh))|v(b)>((vthresh))|v(c)>((vthresh))|v(d)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}}&v(b)>{{vthresh}},{{vss}},{{vdd}})}"
Error: undefined symbol in: "if([v](a)>((vthresh))&v(b)>((vthresh)),((vss)),((vdd)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}}&v(b)>{{vthresh}}&v(c)>{{vthresh}}&v(d)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](a)>((vthresh))&v(b)>((vthresh))&v(c)>((vthresh))&v(d)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§g_u1_abm2i4 outp outn i={limit((v(in1)-v(in2))*{{gain}},{{imin}},{{imax}})}"
Error: undefined symbol in: "limit(([v](in1)-v(in2))*((gain)),((imin)),((imax)))"
Questionable use of curly braces in "b§e_u1_abm2i4 outp outn v={limit((v(in1)-v(in2))*{{gain}},{{vmin}},{{vmax}})}"
Error: undefined symbol in: "limit(([v](in1)-v(in2))*((gain)),((vmin)),((vmax)))"
WARNING: Less than two connections to node u1:u4_neg_cmd. This node is used by e:u1:_u4_e19.
WARNING: Less than two connections to node u1:u4_vy_cmd. This node is used by e:u1:_u4_e18.
WARNING: Less than two connections to node u1:u4_pk_cmd. This node is used by e:u1:_u4_e14.
WARNING: Less than two connections to node nc_01. This node is used by s:u1:_u7_s1:_u7_s1.
WARNING: Less than two connections to node nc_02. This node is used by s2.
d_d1: Emission coefficient, N=0.01, too small, limited to 0.1
u1:_u4_u631:d_d1: Emission coefficient, N=0.01, too small, limited to 0.1
u1:_u6_u691:d_d1: Emission coefficient, N=0.01, too small, limited to 0.1
u1:_u5_u22:d_t: Emission coefficient, N=0.001, too small, limited to 0.1
u1:_u5_u32:d_t: Emission coefficient, N=0.001, too small, limited to 0.1
Direct Newton iteration failed to find .op point. (Use ".option noopiter" to skip.)
Starting Gmin stepping
Gmin = 10
Gmin = 1.07374
Gmin = 0.115292
Gmin = 0.0123794
Gmin = 0.00132923
vernier = 0.5
vernier = 0.25
vernier = 0.125
vernier = 0.0625
vernier = 0.03125
vernier = 0.015625
vernier = 0.0078125
vernier = 0.00390625
Gmin = 0.00106338
vernier = 0.00195312
vernier = 0.000976562
vernier = 0.000488281
Gmin = 0
Gmin stepping failed
Starting source stepping with srcstepmethod=0
Source Step = 3.0303%
Source Step = 33.3333%
Source Step = 63.6364%
Source Step = 93.9394%
Source stepping succeeded in finding the operating point.
Ignoring empty pin current: Ix(u1:en_uvlo)
Ignoring empty pin current: Ix(u1:fb)
Heightened Def Con from 2.36754e-05 to 2.36754e-05
Can someone please advise? Thanks
