Other Parts Discussed in Thread: BQEVSW, BQSTUDIO, EV2400
Dear TI experts:
We found that in our prodtion, it occasional happen that some parameters are not the same as the GG file shows.
Just note that we use bq Evaluation Software in production to import GG file.
we exported the FLASH data from 20 pcs finished goods and found 2 of 20 pcs met below issue:
the FC Set % changed to 0, not 100 as we set.
the FC Set% is a threshold value, from my understanding, it should not change.
Did you ever meet such issue?
if yes, can you tell me the root the cause for such change?
If not, what is the possible reasons?
And how to make sure that there is no parameter difference in production?
Can we check some where in the SW to avoid such issue?
Thanks in advance!
