TPS61221: Vin > Vout
Part Number: TPS61221
Other Parts Discussed in Thread: TPS61299,
the following thread said "The output voltage will track the input voltage.  As Vin goes higher, Vout goes higher.  There will be a voltage drop across the IC that is a function of the load current.".
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/33823/what-happen-if-the-input-voltage-is-higher-for-a-boost-converter?tisearch=e2e-sitesearch&keymatch=TPS61221#
Does this work the same when EN= High?
If you have an image like TPS61299, please let me know.
Nishie
