First of all, please advice if we should use OUTA or SRA for input to gate driver if gate driver only needs 1 input. I suspect answer is OUTA, but please confirm.
Main question is tied to controlling duty cycle of OUTA. It is stuck at around 4.6% (note: frequency is 200kHz). How to increase duty cycle?
In discussion board, someone mentioned use COMP, but that pin is an output, so did not attempt to use to avoid damage. Tried using Vsense to control Duty Cycle, but that too does not seem to work. Appreciate your guidance.
