TLV716P: Verification of device output pins
Part Number: TLV716P
On the TLV716P3318 device I am assuming that the 3.3 v is on the Pin labeled OUT1 (1)
and 1.8v is on the pin label OUT2 (2).  I would like to verify before releasing the design and I could not
find any documentation on this.
  • Hi Charles,
    Sorry about that.  Your assumption is correct.
    Here is the table from the previous revision of this datasheet which was accidentally removed.  I've added this to our datasheet correction log and this will be corrected during the next revision of this datasheet.
    Stephen
