LMR43620-Q1: PG low Test
Part Number: LMR43620-Q1
I want to check the fault when the LMR436x0-Q1 output terminal is abnormally operated.
and apply a voltage to the output voltage terminal that is larger or smaller than the normal voltage.
However, the PG signal did not low
I would like to know how to make a test that PG falls to low when the output voltage is abnormal.
To summarize, how can I intentionally test an abnormal output voltage?
