LP8733: Power down sequence mismatch with AM64x
Part Number: LP8733
Other Parts Discussed in Thread: AM6412, TPS745
My customer is using LP873364 for AM6412 power supply as it is recommended solution in below document.
https://www.ti.com/jp/lit/an/slda059/slda059.pdf?ts=1690441858442&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252Fja-jp%252FAM6421%253FkeyMatch%253DAM6421%2526tisearch%253Dsearch-everything%2526usecase%253DGPN
But they found there is power-down sequence mismatch between AM64x and LP873364.
Here is LP873364 power down sequence. All power rails are off simultaneously.
https://www.ti.com/lit/ug/snvu810/snvu810.pdf?ts=1641848546273
On the other hand, AM64x power down sequence requires VDD_CORE needs to be shut of last if VDD_CORE=0.75V.
https://www.ti.com/lit/ds/symlink/am6421.pdf?ts=1690442004964&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252Fja-jp%252FAM6421%253FkeyMatch%253DAM6421%2526tisearch%253Dsearch-everything%2526usecase%253DGPN
Q1) Why there is such mismatch even LP873364 is recommended for AM64x?
Q2) What is consequence if above power-down violation is applied to AM64x?
(device reliability issue, etc.)
Thanks and regards,
Koichiro Tashiro
