We are planning to use the BQ25170J Charger IC for our Li ion cell, which has 10K NTC inbuilt in it.
When charging, the thermistor inside the battery will be connected to Charger IC TS pin and it will monitor the battery temperature.
When discharging, the same thermistor inside the battery will be connected to Microcontroller as a voltage divider circuit.
When charging, the supply connected to the controller will be disconnected using load switch. So, it will no create any voltage during charging in thermistor
Will this be okay.?
Can we connect same thermistor pin to both Controller and Charger IC?
