BQ34Z100-DEVICE-FW: After updated FW to version 0100_2_01 EVM shows zero voltage and current
Part Number: BQ34Z100-DEVICE-FW
Other Parts Discussed in Thread: BQ34Z100-G1, BQSTUDIO, BQ34Z100
Using BQstudio I updated the FW of the bq34z100-g1 in the EVM. Following the update bqstudio correctly identifies the EVM and shows active communication with the board. After the update I programmed the chemistry and updated the data memory parameters to fit the lead acid 6 cell battery I am using. All programming completed successfully.
However, I am unable to calibrate the board as both voltage and current values are zero and not affected by anything I do.
Any ideas what to try next?
Thank you
