TPS51200-Q1: Can VLODIN be powered up before VIN?
Part Number: TPS51200-Q1
on page 12 and 13 of the datasheet for TPS51200-Q1 it shows a diagram of the typical power up. https://www.ti.com/lit/ds/symlink/tps51200-q1.pdf?ts=1691074369828&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FTPS51200-Q1%252Fpart-details%252FTPS51200QDRCRQ1
Is it required to always power Vin (3.3VDC) before VLODIN?(1.2V in this case), or can VLODIN be powered up before Vin?
  • Hi David,
    Thanks for the inquiry. Yes, you can power VLDOIN/REFIN before VIN/EN. However please note that when the device has this for a power sequence, you will experience some overshoot on the output but should operate normally thereafter.
    Field
