We are using TPS57114C-Q1 as 1V8 regulator. Can we externally supply 2.5V at the output of this regulator when this regulator is off /ON condition?
will there be any impact ?
Thanks & Regards,
Rackshith PG
Thanks & Regards,
Rackshith PG
Hi Rackshith,
It is okay to use configuration with protection for reverse current flow. It can damage device.
You can use either method to avoid it. https://www.ti.com/lit/an/slva730
Tanvee
