Other Parts Discussed in Thread: UCC256404,
On the specs page I see that this device supports systems with power less than 150W.
I planned to use this part with UCC256404 LLC controller, as suggested on the datasheet of the LLC controller. Output power will be 200W max, with 100W nominal Pout. Is this still doable. If not, can you suggest alternative PFC module for this application?
