Hi Dear,
The customer uses BQ24296. If the BQ24296 software is not configured and VBUS is powered normally, but there is no battery connected to the system, can VSYS output normally?
Hi Dear,
Hi Anna,
If the BQ24296 is to be used without a battery connected /CE pin needs to be pulled high to disable charge. When no battery is attached charge needs to be disabled to allow for VSYS output to function normally.
Garrett
