I want to use the BQ298015 as a system-side protector in a product with a replaceable 18650 Li-Ion cell.
The product should be able to turn on after inserting a full battery cell, even if there is no charger attached.
According to the datasheet, this should be possible on a BQ2980 variant without UV_SHUT enabled, however all the variants of the datasheet have UV_Shut enabled.
Is there a reason for that? Are there variants without UV_Shut available that are not listed in the datasheet?
According to some previous answers in this forum, it should be possible to power-up the protector without a charger, even with UV_Shut enabled, if the load current is low enough.
My standby load current (device switched off) would be around 25-30µA. However even with the protector running isolated without any load, it does not turn on without a voltage on the charger side.
Can you provide a workaround to supply the charger side from the battery during battery connect, without impeding the protection function of the chip?
However I would prefer to acquire a variant with UV_Shut disabled, where no workaround is needed.
The BQ297 also needs a charger to power up, as do protection chips from maxim/analog. Diodes inc do not produce battery protection chips anymore.
I don't understand why nobody wants to manufacture a system-side battery protection chip that doesn't need a charger to power on, but I do believe there is a market for this, as other questions in this forum also asked for this behavior.
Thanks, Friedolin
