My customer would like to verify the UCC28180 output OVP function.
From the datasheet,I know the Vsense pin over 107% of reference will trigger the function.
According my design,resistance Vsense_upper is 1.037M and Vsense_lower is 13.7k,so the OVP point should be about 418V.
But how do I test this function?
If I use the variable resistor as Vsense_lower to change output for above OVP point,the feedback resistor ratio into Vsense also changed for keeping Vsense at reference voltage.
Does anyone verify the OVP function before and how to test it?
