I'm troubleshooting a circuit that uses the ptn78000h to generate +15 VDC from an input voltage of +28 VDC. I suspect this circuit is drawing too much DC current from
the +28 VDC power supply. I'm using a bench power supply to provide the +28 VDC with the supply's overcurrent protection set to +1.0 amp.
As soon as I turn on the +28 VDC power supply output, the overcurrent protection is tripped. What is the specfication on the ptn78000h's start up inrush current?
Thanks for your help.
