Hi team,
could you help on the following questions:
- Time required for current/temperature detection,( this is the time from the temperature (current) anomaly to the shutdown of the output )
- Whether the test is determined by multiple tests or is closed as soon as a peak reaches?
- Recovery time,Recovery time, the time from when the chip detects that the temperature (current) returns to the normal range to the normal voltage output
thanks
