TLC69601: Some application questions
Part Number: TLC69601
Hello Sir:
We have some application questions which needs your help, please refer below.
1. do you have single layer layout example? can you share it for us?
2. Datasheet mentioning CLK_O can series to 1024 pcs IC, can you let us know what is the maximum driver IC quantity that your customers typically use?
3. If customer frame rate is 166Hz/VRR, then 1 SPI series 36pcs TLC69601,  can you tell us the range of minimum clock frequency, did you have formula on it?
Looking forward your feedback.
Thanks a lot.
