Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TPS2546: Comparison with TPS2544
Part Number: TPS2546
Other Parts Discussed in Thread: TPS2544,
Hi Expert,
Do we have comparison table or slide can show the different between the TPS2544 and TPS2546?
Far
  • Hi Far,
    The primary difference between TPS2544 and TPS2546 is that the TPS2546 also supports two distinct power management features, namely, power wake and port power management (PPM) through the STATUS pin. Power wake allows for power supply control in S4/S5 charging and PPM the ability to manage port power in a multi-port application.
    Other than this the parts behave the same.
    Let me know if you need anything else.
    Matt
