i will build a unregulated Push-Pull-Converter with the UCC2808A-1.
At fixed 200kHz it should run at nearly 90% Duty-Cycle.
The Current should be limited at nearly 1,2A.
I'm a little bit confused how to set the Current-Limit and what to do with the COMP-Output. At this time i had not found some
App-Note or so, with the necessary information...
ARC
