TPS566238PEVM: PG pin requirements
Part Number: TPS566238PEVM
Datasheet recommends to connect a pull-up from powergood pin to VCC pin as I show you at the picture below:
However, VIN can reach up 12V so as 12V is bigger than 5V VCC LDO output, VCC=VIN=12V. However, PG pin only stand up 6V.
So could I connect PG pin as I show below instead of datasheet recommendation?
Thank you in advance
