TLC59116: TLC59116 questions
Part Number: TLC59116
Hi team,
Could you pls help with the following questions about the tlc59116: 1. Is the output of this IC in the default high-impedance state when it is powered on? 2. What is the voltage drop of the IC's out pin when the light is on? Is the voltage drop fixed for different currents? 3. Does the driver have arm linux 3.0 driver or microcontroller driver?
Thanks!
Rayna
  • Hi Ruixin,
    I am out of office and I will reply to you in next Monday, thanks for your understanding.
    BR, Jared
  • Hi Ruixin,
    For your questions, please find the comments below:
    1. Is the output of this IC in the default high-impedance state when it is power on?
    [Jared]: Yes.
    2. What is the voltage drop of IC's out pin when the light is on? Is the voltage drop fixed for different currents?
    [Jared]: For the voltage drop of IC's out pin, you can refer the the below figure.
    3. Does the driver have arm Linux 3.0 driver or microcontroller driver?
    [Jared]: For the Linux driver, I find a link on ti.com. I am not sure if it can meet your requirement. For the microcontroller driver, I will write it for you and reply to you later.
    BR, Jared
