TPS54160: Question about thermal pad size change.
Part Number: TPS54160
Hello guys,
One of my customers has been using TPS54160DGQ for their mass-production.
Recently, they received PCN of the device (PCN# 20230928002.1).
The PCN says that new assembly site, HFTF was added and qualified.
Also it says HFTF's package thermal pad size is bigger than the original package assembled at UTL/ASESH site.
At this moment, they have the following questions.
Could you please give me your reply?
Q1.
Are PCB land pattern and solder mask opening size needed to change due to new assembly site package addition?
If the answer is yes. could you please tell me the recommended size?
Q2.
If the answer to Q1 is No, is it no problem to solder though the additional package thermal pad size is larger than solder mask opening size?
Your reply would be much appreciated.
Kazuya.
