Hi Team,
From datasheet page 29, it doesn't show thermal pad, but the real product has.
Could you help double check if the thermal pad is contacted to GND or not ? And help update the datasheet.
Thank you!
Marc
Hi Team,
Thank you!
Marc
Hi Marc,
The part is currently released in the D package, which has no thermal pad. There is also a DGN version mentioned in the datasheet, which does have a thermal pad. Currently, only the D package version is released for purchase. Once the DGN is released, those package pages at the end of the datasheet should automatically update.
The pad is explained on the pinout section of the datasheet. It should be connected to GND, but it isn't a low-impedance path to GND (so you can't skip routing the GND pin).
Alex M.
Hi Alex,
Thanks for the reply! When will UCC27444QDGNRQ1 be released on TI.com?
Thank you!
Marc
Hi Marc,
I don't have access to that information. Most likely within the next month, but there is no guarantee.
Alex M.
