TPS746-Q1: Shutdown from Enable
Part Number: TPS746-Q1
Could you please provide the Shutdown from Enable timing diagram of TPS74601?
The picture below shows the power-on and power-off test chart of the TPS74601 power supply. The power-off time is much longer than the power-on time, about 1.85ms.
Please help analyze whether it is normal?
  • Hi Ray,
    There is no turn off time spec.
    The turn off time depends on the output cap used, the current being drawn, and output pull-down, if present in the part.
    Since all these factors affect turn off time, it is normal for the turn-off time to differ from the turn-on time.
    Also, turn-on time is controlled by a circuit and turn-off time is mostly system dependent.
    Bobby
  • HI Bobby,
    Thank you for your answer. The customer wants to shorten the drop time of en, what improvements can be made?
    I have already sent the client's schematic diagram to your email
    Ray
  • Hi Ray,
    Reducing the value of output cap will help shorten the turn off time.
    If this is not possible, a resistor can be put in parallel with Cout(but that would decrease efficiency by dissipating power all the time).
    So, you could add a switch to discharge the Cout through a resistor. Take the Enable signal, invert it, and then drive a transistor with a resistor in series.
    Bobby
