Part Number: TPS65220
Other Parts Discussed in Thread: TPS65219
Hi Team ,
we are developing a hardware based on AM6442ASFGGAALV. We have following initial queries .Please help
Hi Team ,
Hi Nikhil,
Thanks for reaching out. The TPS6522053 PMIC comes pre-programmed with the required NVM settings to meet the AM64x power/sequence requirements. No need for SW programming. This PMIC variant can power the AM64x processor with VDD_CORE=0.75V, LPDDR4 and other peripherals. Below are the links to the resources available to assist your design. Let us know if there are any questions.
Brenda
Hi Brenda,
Thank you for the response . We are using DDR4 (not LPDDR) . We need to reconfigure for DDR4 (1.2 V) ? Our input voltage is 5V
Hi Nikhil,
Does your application need the PMIC to support extended temperature (125C ambient, 150C junction)? If not, we recommend using one of the options listed below to power the AM64x + DDR4 with a 5V input supply. The TPS65219 PMIC is functionally equivalent to TPS65220 and pin to pin compatible. It supports temperature up to 105C ambient and 125C junction. Let us know if you have any questions.
Options to power AM64x + DDR4 with 5V input supply:
Brenda
Thank you Brenda ,
looks TPS6521901 would be the right choice for us . VDD_CORE to be 0.75V, right ?
we are planning to use LDO1 for 3v3 for peripherals . Buck2 is also 3V3 for the SOC.
SOC itself would require >1A for 1.8V ?
Hi Nikhil,
Please find my feedback below and let us know if you have any questions.
Brenda
