Hi Team,
The data sheet, 8.2.1.2.5 VTTSNS Connection section, says as bellow.
"Consider adding a low-pass R-C filter at the VTTSNS pin in case the ESR of the VTT output capacitor(s) is larger than 2 mΩ.The R-C filter time constant should be approximately the same or slightly lower than the time constant of the VTT output capacitance and ESR."
What is the purpose of having a time constant here?
