Part Number: TL1431-EP
Hi team,
I am looking at the datasheet of the TL1431-EP. I am trying to follow the detailed design procedure and am finding some discrepancies I hope you can clarify.
1. Equation 5 uses the value 1.1mV, but equation 2 has this value as 1.5mV. Which value should be used here?
2. Equation 6 uses a Zka of 2 Ohm, but everywhere I look in the datasheet has Zka as 0.2 ohm. Which value should be used here?
Emma
