when I use 250Hz PWM to drive the chip's EN pin there is a chance to trigger the FAULT pin, not sure which fault it was.
But the chance will be much higher if I change the duty cycle dynamically. i.e. change the brightness from dim to 100%.
It happens with or without load present. I thought this chip is PWM capable?
