Hi Team,
Could you possible help to check for below recommend inductor and capacitor value, if this is the value for inductor or capacitor typical vaule or should it consider the tolerance for the inductor or capacitor value?
For example, for inductor, if customer want to use 1.2uH inductor, could their inductor use a type value 1.2uH and with maximum/minimum value 1.2uH±20%? Thanks a lot for your support to double check.
Best regards
Jie
