Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TLV62065: TLV62065TDSGRQ1
Part Number: TLV62065
Customer uses TLV62065TDSGRQ1 in A-LKAS project. Customer requested us to provide the AEC-Q006 qualification result data for PCN#202209120000.2 due to consider to accept this PCN. Could you please provide them?
  • Hi Takashi,
    Thanks for contacting us.
    The AEC-Q006 standard was introduced after TLV62065TDSGRQ1 was released.
    However, the device is considered AEC-Q006 compliant since the AEC-Q006 specification states that if a device has been previously qualified for Cu wire, it meets the AEC-Q006 requirements and isn’t required to complete additional specific AEC-Q006 testing.
    Please let me know in case of further concern.
    Thanks!
    Yann
  • Hi Yann,
    Thank you so much for you prompt reply.
    I understood it meets the AEC-Q006 requirements and isn’t required to complete additional specific AEC-Q006 testing.
    However, could you please provide an original AEC-Q006 tested results for TLV62065TDSGRQ1 ?
    Thanks & Regards,
    Takashi Anazawa
  • Hi Takashi,
    There are no original AEC-Q006 test results for this device.
    The reason is that at the time the device has been originally qualified, the AEC-Q006 standard didn't exist yet. And the AEC-Q006 standard specifies that for such devices with previously qualified Cu-wire process, there is no need for AEC-Q006 qualification.
    Thanks!
    Yann
